Sarabpaints
Sep 26, 2022Follower
Rbr50 reset Orbi and now it won’t connect to the Internet
I have an Orbi90 rbr50 and it won’t connect to the Internet. Every time I restarted it it would go back to the pink light. So I reset it and now it is a white light but it is still not working. How do...
Jeezy
Sep 29, 2022Tutor
OP did you manage to sort this? I am having the same issues.. wirelessly I am getting slow speeds. I tell you what Netgear Orbi is a pain in the ass. I regret getting this. You would expect for such a expensive equipment you wouldn’t have much headache with it
Sep 29, 2022Guru - Experienced User
The user hasn't been back since they posted nor responded to my suggestions.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
