pbdorders's avatar
pbdorders
RBR50 Router Admin Speed test much faster than when tested internally
When in the administrative settings for my Orbi RBR50, if I run a Speedtest it tends to read 800-850mbps. I subscribe to a 1GB service. On the LAN, I mostly get 130-150 mbps wired, and 80-150 wireless...
  • FURRYe38's avatar
    May 02, 2024
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How are you speed testing on the laptop PC? Web page speed test? Ooklas installable speed test app is recommended.
    Does trying a different wired PC result in same speeds seen with 1st PC?
    Armor, Smart Parental Controls or Circle, Traffic Meter.
