Mb151273's avatar
Mb151273
Follower
Aug 08, 2020
Rbr50 router and rbr20 satellite
Does the rbr50 router work with a rbr20 satellite? They connected to each other, but I’m try to hook up a stereo up to the Ethernet port and the stereo doesn’t get an internet signal. Also hooked you to my laptop and nothing.
1 Reply
  • CrimpOn's avatar
    CrimpOn
    Please look closely at the model number on the product label of the satellite.
    RBR20 refers to a "router" and RBS20 refers to a "satellite".  An RBS20 should connect with an RBR50 router and work.  An easy way to check is to open the Orbi web interface (http://orbilogin.net) and click on Attached Devices.  Satellites appear at the top of the page.
