mikeuk24
Oct 10, 2020Aspirant
RBR50 Router. And satellite with Virgin Media SuperHub3 constantly dropping signal
I am using an Netgear ORBI RBR50 as router with one satellite, and a Virgin MediaSuperHub3 as modem. The router and modem are connected by Ethernet cable. The satellite is connected wirelessly. ...
Mstrbig
Oct 11, 2020Master
After you changed the ISP modem, did you reconfigure the Orbi router? Now that the ISP modem is in modem mode, you may want to factory reset the Orbi router and re-install, just to make sure it grabs what is needed from the ISP and configures itself in router mode.
