Wiessmueller
Nov 09, 2024Follower
RBR50 Router compatible with AX5400
is the orbi AX5400 compatible with the 0rbi RBR50
1 Reply
Not with the 50 series. You could use the 50 series in access point mode if you wanted a secondary network.
Here's the orbi compatibility chart.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
