wodge
Oct 29, 2019Aspirant
RBR50 Router Firmware Version V2.5.0.38 - Access Control = 500 Internal Server Error
I have updated my Orbi RBR50 to the latest firmware version V2.5.0.38. Now I cannot access the Access Control section and see no devices in the Attached Devices section. Is this a known issue or...
emeraldpatriot
Dec 14, 2019Aspirant
Did you ever find a resolution? I had the same issue, patched to V2.5.0.40. I still am getting the same message after a couple of months. The first symptom is that we experience slow internet access times sporadicly. Then the iphone apps won't let me login with admin password, says its incorrect, but it isn't. Then when we try to log on via wired web browswer we are able to but get the same 500 internal server error or may get a text only interface the is all but unusable.
techrealm
Jan 11, 2020Aspirant
I had the same error, somhow I downloaded RBS50 firmware instead of RBR50. And with my bad eye sight and even worse font for viewing the .img file for upload - repeatedly kept using the wrong firmware. Once I downloaded the correct firmware and cleared my IE cache etc it worked fine.
- FURRYe38Jan 11, 2020Guru - Experienced User
What FW version are you using now?
techrealm wrote:I had the same error, somhow I downloaded RBS50 firmware instead of RBR50. And with my bad eye sight and even worse font for viewing the .img file for upload - repeatedly kept using the wrong firmware. Once I downloaded the correct firmware and cleared my IE cache etc it worked fine.
