wodge
Oct 29, 2019Aspirant
RBR50 Router Firmware Version V2.5.0.38 - Access Control = 500 Internal Server Error
I have updated my Orbi RBR50 to the latest firmware version V2.5.0.38. Now I cannot access the Access Control section and see no devices in the Attached Devices section. Is this a known issue or...
siquenique
May 17, 2020Aspirant
I am having this issue with version 2.5.1.8 does anyone know how to fix it?
May 18, 2020Guru - Experienced User
Perform a full factory reset on both router and satellite(s) then set up from scratch.
- relberfeldAug 26, 2020Apprentice
clearly netgear doesnt know how to fix this. and they dont know why the error is even happening. reseting the router is NOT A FIX. Does anyone at netgear have a clue how to resolve this ? I am about to trash $1000 worth of ORbis because of this issue.
- MstrbigAug 26, 2020Master
relberfeld wrote:clearly netgear doesnt know how to fix this. and they dont know why the error is even happening. reseting the router is NOT A FIX. Does anyone at netgear have a clue how to resolve this ? I am about to trash $1000 worth of ORbis because of this issue.
What have you tried so far?
What firmware version are you on now?
Mr RBK53 system is on firmware 2.5.1.16, which is the official release, and the system is flawlessly rock solid. Others are on newer firmware and have mixed results. Some are good, others have issues.
I am on 2.5.1.16. When I reboot the problem goes away for a while, then starts to fail with 500 error when I access remotely. (only way I can do since I am 800 miles away). Then some of the connected devices slow down and eventually disconnect. No changes on any end since the firmware upgrade months ago. This is only a recent issue.
