wodge
Oct 29, 2019Aspirant
RBR50 Router Firmware Version V2.5.0.38 - Access Control = 500 Internal Server Error
I have updated my Orbi RBR50 to the latest firmware version V2.5.0.38. Now I cannot access the Access Control section and see no devices in the Attached Devices section. Is this a known issue or...
relberfeld
Aug 26, 2020Apprentice
clearly netgear doesnt know how to fix this. and they dont know why the error is even happening. reseting the router is NOT A FIX. Does anyone at netgear have a clue how to resolve this ? I am about to trash $1000 worth of ORbis because of this issue.
Mstrbig
Aug 26, 2020Master
relberfeld wrote:clearly netgear doesnt know how to fix this. and they dont know why the error is even happening. reseting the router is NOT A FIX. Does anyone at netgear have a clue how to resolve this ? I am about to trash $1000 worth of ORbis because of this issue.
What have you tried so far?
What firmware version are you on now?
Mr RBK53 system is on firmware 2.5.1.16, which is the official release, and the system is flawlessly rock solid. Others are on newer firmware and have mixed results. Some are good, others have issues.
- relberfeldAug 26, 2020Apprentice
I am on 2.5.1.16. When I reboot the problem goes away for a while, then starts to fail with 500 error when I access remotely. (only way I can do since I am 800 miles away). Then some of the connected devices slow down and eventually disconnect. No changes on any end since the firmware upgrade months ago. This is only a recent issue.
- MstrbigAug 26, 2020Master
If you are 800 miles away and relying on Internet, the issue may have nothing to do with your Orbi system. Have you tried connecting from another location, using another ISP connection? Also can you change the DNS servers at the location you are at now?
yes, I tried several ISPs, and same issue. Again, nothing changed on my end. I spent 30 years in network support, I can tell you without hesitation that this is a Netgear issue. Based on other peoples comments, they would agree. The point of remote access is just that, remote access. netgear continues to try to blame everything but their firmware, and fails to recognize that this issue started when they changed to the new "access anywhere" and updated the firmware.
Time for the google wifi, netgear is out of their league on this product.
