Taffynz62
Mar 29, 2020Follower
RBR50 router not connecting
Running Netgear Orbi RBR50 with Huawei B618s-65d wireless modem. Satellite is green in my network diagram but the base router is red. Internet is slower than before I bought the Orbi.
Considering sending it back and asking for my money back!
Can someone help me to get the base Netgear router to work?
Thanks,
Jack.
1 Reply
If your modem has a built in router and wifi, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
