EleanorRigby
Apr 29, 2022Tutor
RBR50 Router Not Found?
I'm getting "Router Not Found" when launching apple Orbit app and the RBR50 is showing as disconnected. However, I have full operational Wifi service in the home, including normally functioning t...
Jeffgear
Apr 30, 2022Virtuoso
Have you tried deleting the Orbi app from your phone and re-installing? Is the phone on your WiFi and getting internet ok? Have you tried rebooting the router and all satellites, relaunching Orbi app?
EleanorRigby
Apr 30, 2022Tutor
Yes to all of those things. WiFi and Internet and working perfectly with 500MB down on phone speediest
Router & Satellites have been rebooted.
Phone app deleted then reinstalled.
After reinstalling phone app, I'm told network can't be found and router is offline
- JeffgearApr 30, 2022Virtuoso
Have you tried enabling "Anywhere Access" in the Orbi app, that's the cloud symbol on the top left of the apps's Home Screen, then select Settings and it should be listed as an option to enable. I connect with anywhere access so I can manage my mesh externally.
Have you tried installing the Orbi app on another phone or iPad associated with your WiFi? I've got the Orbi app installed on my iPhone and iPad and both work ok.If this gives the same result then I'd take the option of last resort and reset the router to factory default and rebuild.
good luck!- EleanorRigbyApr 30, 2022Tutor
Accessing it from my iPad did the trick.
Now everything looks correct on my iPhone.
Weird gremlin, but all appears normally operational again
thanks!
- JeffgearApr 30, 2022VirtuosoWow that’s a result of sorts. It would be great to solve the phone-side issue though. Does Anywhere Access fix it for the phone’s version of the Orbi app?
Perhaps you’d like to give me kudos? 🙂
