Adomatic
Jun 20, 2021Tutor
RBR50 Router Playing Dead?
Our Orbi RBR50 router stopped making a wifi network and the two satelites connected to it won't sync. I've done a number of things based on feedback in this community and other research. Currently,...
Adomatic
Jun 20, 2021Tutor
Thanks for the reply. Right now, when I power on the rbr50, the power light turns green and the top ring flashes white. After a minute or so, the power light flashes red five times and then turns green and the top ring continues to flash white. During this process, I can hold the reset button down for over a minute and nothing happens.
Adomatic
Jun 20, 2021Tutor
I should also note that no network is ever presented from the orbi during this process either. If I hold reset and power on and let it boot that way, I can sometimes get it to present a network through the iPhone app but I haven't had any luck actually getting onto that network or even having it presented for more than a few minutes before it also seems to disapear.
