FZ1977
Feb 03, 2021Tutor
RBR50 Router
Hello All. Trying to update the firmware on my Orbi router. Working on a manual update. When I attach the .img file, click upload, it processes for a few minutes then an error message appears stating...
Feb 03, 2021Guru - Experienced User
What version of FW are you trying to update too?
What browser are you using?
- FZ1977Feb 03, 2021Tutor
I'm trying to update from 2.0.0.74 to 2.7.2.104.
ISP modem Hitron, model # EN2251 (Spectrum)
Google Chrome on my MAC
- DeanB1452Feb 03, 2021Apprentice
From the release notes in the older firmware selections on the support page it states: Note:If your firmware version is 2.2.1.210 or lower, you cannot update the firmware directly to v2.3 or higher. You must first update the firmware to v2.2.1.212 using the manual firmware update feature in the router web interface. After updating the firmware to v2.2.1.212, your Orbi router reboots, and then you can update to higher versions.
Unfortunately, the lowest version on the support page is v2.3.1.44. Hopefully someone has that available for you to bump up your Router.
- FURRYe38Feb 03, 2021Guru - Experienced User
v212 is available on the RBK50 support page:
https://www.netgear.com/support/product/RBK50.aspx#download
Select the Previous versions download towards the bottom of the FW list.
