JR213
Apr 16, 2023Aspirant
RBR50 Router
my router is set up to use Ethernet cable or fitting for "internet port" my new home uses coax cable hookups...is there an adapter that enables use of ethernet to coax hookup?
JR213
thanx for your reply. noticed there is an adapter than converts female ethernet fitting to coax fitting...use this maybe?
CrimpOn
Apr 16, 2023Guru - Experienced User
Modem: Modulator-Demodulator (https://en.wikipedia.org/wiki/Modem ) Not a simple adapter.
Data Over Cable Service Interface Specification (DOCSIS) is the type in use these days.
https://en.wikipedia.org/wiki/DOCSIS
