Keeto123's avatar
Keeto123
Follower
Feb 16, 2021
RBR50-RS50- RBS40v
Hello
I have the Orbi RBR50 +Rbs50+ RBS40v. Do you have any recommendations on the order it is linked ? As 1 /2 / 3. I have 3 floors and trying to get he best speeds. Lan is also available if it will help thanks
1 Reply
  • plemans's avatar
    If you have them hardwired using the wired backhaul, then it doesn't  matter.
    Same if you're setup in a star configuration because the satellites would connect directly back to the router.
    But if you're daisy chaining then go RBR50-->RBS50---RBS40V
    star: RBS50<-------RBR50------>RBS40V
    daisy chain: RBR50---->rbs50----->rbs40v.
