Yoyoyo's avatar
Yoyoyo
Follower
Sep 03, 2019
RBR50 satellite connection to Ipad is very slow
Hey,
Recently set up the RBR50 with one satellite and noticed the connection speed on my ipad and iphone slow down to a crawl every few minutes when they're connected to the satellite.   Any ideas?
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
