paulc1978
Aug 18, 2022Aspirant
RBR50 satellite devices
I have the Orbi RBR50 (in the lounge fairly close to the garden satellite) with 2 satellites, one in the garden summerhouse (hard wired) and one upstairs. Is it possible to set any devices in the gar...
Aug 18, 2022Guru - Experienced User
No. there isn't a way to set them to a specific satellite. They roam based off their own roaming protocol.
If you have 2 much coverage through, it can cause more frequent roaming. You could try turning your broadcast power from 100% down to 75% and see if it helps.
- paulc1978Aug 21, 2022Aspirant
Hiya
Ok, thanks for your suggestions. I will try this and see if it works
