DanTyler
May 23, 2019Aspirant
RBR50 Satellite issue
Hi all I am having a lot of issues with connectivity of one of my satellites. I want it to connect to the main RBR50 router but instead it connects to my other RBS50 which then causes it to go am...
- May 23, 2019
Please disable "Daisy Chain" under advanced wireless settings, so all Satellites will be then forced to connect only to the Router.
ekhalil
May 23, 2019Master
- DanTylerMay 23, 2019Aspirant
Thanks for the response. Where can i find advanced settings?
- ekhalilMay 23, 2019Master
DanTyler wrote:Thanks for the response. Where can i find advanced settings?
You need to use a browser on your computer to navigate to orbilogin.com to get the Orbi web GUI.
The Advanced Wireless Settings can be found as in the attached.
Thank you for all your help all sorted! :smileyhappy:
