alexpollard
Aug 07, 2020Aspirant
RBR50 Satellite keeps dropping connections
Connection has been rock solid since I bought it but recently my satellite connections keep dropping. I know because I lose connectivity to my NAS connected over ethernet. Rebooting the satellite eve...
Aug 07, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Has a factory reset and setup from scratch been performed since last update?
- alexpollardAug 07, 2020Aspirant
Firmware is V2.5.1.32
Virgin Media UK in Modem Mode
Tried messing with a few settings - wireless has been rock solid as I say for around a year since I bought it, it's only recently that it has started playing up. I get full speed pretty much everywhere in my house.
Yes but I restored my settings as I have many port forwards etc for the NAS and it would be a right pain to set this all up again.
- FURRYe38Aug 07, 2020Guru - Experienced User
You might downgrade to v16 on the RBR and RBS. v32 saw some problems. NG pulled this version from there servers.
Factory rest the RBR and RBS and setup form scratch. Don't apply the backup config from file initially. See if the RBS fails again. If not, then try loading the backup config from file.
- alexpollardAug 07, 2020AspirantIt took about 4 weeks before it dropped again since I updated the firmware so it’s really intermittent. Probably only happens once every 2 weeks or so but it’s really irritating.
Might downgrade again and see.
