KennyB43
Jun 28, 2020Aspirant
Rbr50 satellite not supported on orbi app
I have an Orbi system with base and 1 satellite that I have hard wired through the base. It was working just fine, then suddenly I cannot connect to it via wifi. The devices I have hard wired to the s...
Jun 28, 2020Guru - Experienced User
Be sure RBR and RBS are loaded with same version of FW.
Has a factory reset and setup from scratch been performed since last update?
KennyB43 wrote:
I have an Orbi system with base and 1 satellite that I have hard wired through the base. It was working just fine, then suddenly I cannot connect to it via wifi. The devices I have hard wired to the satellite (smart tv, xBox) work just fine, but I cannot connect my Wireless devices. When I pull up the orbi app, the base connects when I’m close, but when I’m closer to the satellite, the app only says router not supported.
Any thoughts?
