vreynolds
Dec 03, 2018Luminary
RBR50 satellite solid magenta - no wifi anywhere
Every time we have a power outage, the satellite ring turns solid magenta, and I have NO WIFI anywhere in the house. Strange that I lose wifi right next to the main router. Hardwired components wor...
vreynolds
More information - I unplugged the satellite and still no wifi. I rebooted the router and still no wifi. Firmware: V2.2.1.210. So it appears the router is not transmitting or something - sorry I am not a techie.
The router hardwired devices work, but no wifi. Seriously, am I going to have to factory reset due to a powere outage??? Any help please.
DickDuke
Dec 03, 2018Apprentice
Have you looked through all of the available WiFi networks after the power outage? The router “should” retain all of its settings, but if for some reason it didn’t, it may show up with the default name.
if your Orbi router and a computer can be connected by Ethernet, you should be able to log into the router to see what’s going on, and then reconnect the satellite.
- vreynoldsDec 03, 2018LuminaryWhen I logged in to the router and it said it was connected. Finally I was able to get it to work by unplugging both units, then plugged in the router first, left it alone for several minutes. WiFi came back on. Then I plugged in the satellite waited several minutes, then synced. It worked. I think initially I didn't have success because I was focusing on the satellite instead of the main router. Hooked up the satellite to a ups now to prevent this from happening again.
