ClintoKL
Aug 09, 2021Apprentice
RBR50 Satellites Connected but No Internet
I have the Orbi RBR50 + 4 satellites and Firmware is 2.7.3.22 (please note that to the best of my knowledge I did not manually perform any firmware update myself, so not sure if this was an automatic...
- Aug 09, 2021
The system will return if you just power OFF the modem and RBR for 30 seconds then back ON. Once the RBR is back online, power ON the RBS.
Last month.
ClintoKL
No, I have not powered on/off the Orbi (or the router that sits behind it - I use Orbi in AP mode) because the Orbi router itself and 1 satellite is working and im very worried if I reboot then nothing will work.
I have powered off/on the ISP modem.
As mentioned I did not manually update the firmware. I do not know when the Orbi (or even if it did) update the firmware automtaically to 2.7.3.22.
When was that firmware released do you know?
Aug 09, 2021Guru - Experienced User
Last month.
