kobekid
Oct 18, 2019Aspirant
RBR50 satellites have gone orange, normally green
On the Orbi app my satelites both just went orange! They have always been green. Tried restarting them but no good. Any ideas how I can get my green back community? Thanks
kobekid
thanks for the reply. There is no colour showing on the actual hardware. Just orange in the app
Retired_Member
Oct 18, 2019
kobekid wrote:thanks for the reply. There is no colour showing on the actual hardware. Just orange in the app
no color on the sats means all is good.
forget the app
- kobekidOct 18, 2019Aspirant
so the app is not 100% accurate?
- Retired_MemberOct 18, 2019
kobekid wrote:so the app is not 100% accurate?
many on here have reported problems with the app.
your best bet is to login via pc to your Orbi router for network status
- CrimpOnOct 18, 2019Guru - Experienced User
Before giving up on this topic, it might be worthwhile to turn the satellite off and back on, then watch the color of the "ring" light. This web page indicates that the satellite ring light will turn various colors as it boots up.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean Amber for 10 seconds means the connection is "fair".
