Jsonadam
Jul 25, 2020Tutor
RBR50 Satellites not showing up on App
I have had the RBR50 for several years. I have 3 satellites in addition to the router. Last night, my internet seemed to crash. Not sure if it was ATT or the router but it came back up after a few min...
Jul 25, 2020Guru - Experienced User
If they're showing up through the online web interface its a good sign.
But if you really want to see them in the app, you might need to reset the router/satellites back to factory.
Or i wouldn't worry about it after everything working fine other than the app display.
Jsonadam
Jul 25, 2020Tutor
Thanks - that is my thought now as I really do not want to set everything back up again and since everything is working fine but....I keep checking the app to see if things have changed as it is killing me that I cannot see the network map even though there is no real reason or need to see it - just bugs the heck out of me as to why it worked and now does not. If something changes and functionality becomes affected I guess I will need to do a factory reset.
- ronealwaJul 26, 2020Star
I noticed this same thing recently. The Orbi satellites (I have 2) no longer show up on the network map within the Orbi mobile app (I am on iOS). The satellites are connected fine and functioning normal. I am guessing some update within the app probably is causing it...and I also do not intend to set everything back to factory defaults just to test if that fixes it or not.
- FURRYe38Jul 27, 2020Guru - Experienced User
Please refer and post about any Orbi app problems in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Thank you.
