paulw007
May 13, 2020Tutor
RBR50 Second hand purchased, how to register
Hi just purchased an Orbi RBR50 with satelite second hand. I have tried to register but it says the product already registed. I have sent an email but no reply as yet. I was hopping someone inthe com...
paulw007
May 13, 2020Tutor
Thank you have sent message, but no reply as yet.
- paulw007May 13, 2020Tutor
I've seen theres alot of people with the same issue as myself. Does anyone have an answer and can I just use my router and satelite units without registering them?
- FURRYe38May 13, 2020Guru - Experienced User
Yes you can use the system with out registering the system. Just walk thru the setup wizard or you can configure the system manually your self. Use the installation guide and user manuals for more help and information.
That's great info. That was what I was looking for. Thank you so much. Will try and get set up. Wish me luck. Thanks again.
