paulw007
May 13, 2020Tutor
RBR50 Second hand purchased, how to register
Hi just purchased an Orbi RBR50 with satelite second hand. I have tried to register but it says the product already registed. I have sent an email but no reply as yet. I was hopping someone inthe com...
May 13, 2020Guru - Experienced User
Yes you can use the system with out registering the system. Just walk thru the setup wizard or you can configure the system manually your self. Use the installation guide and user manuals for more help and information.
paulw007
May 13, 2020Tutor
That's great info. That was what I was looking for. Thank you so much. Will try and get set up. Wish me luck. Thanks again.
- FURRYe38May 13, 2020Guru - Experienced User
Good Luck. :smileywink:
- paulw007May 13, 2020Tutor
All sorted, up and running and very good wifi. Thank you very much for your time and your help. Stay safe and take care.!!!!!
Please mark your thread as solved so others will know.
Be sure to do a back up configuration to file for safe keeping on the RBR. Saves time if a reset is need.
Enjoy. :smileywink:
