paulw007
May 13, 2020Tutor
RBR50 Second hand purchased, how to register
Hi just purchased an Orbi RBR50 with satelite second hand. I have tried to register but it says the product already registed. I have sent an email but no reply as yet. I was hopping someone inthe com...
paulw007
May 13, 2020Tutor
That's great info. That was what I was looking for. Thank you so much. Will try and get set up. Wish me luck. Thanks again.
May 13, 2020Guru - Experienced User
Good Luck. :smileywink:
- paulw007May 13, 2020Tutor
All sorted, up and running and very good wifi. Thank you very much for your time and your help. Stay safe and take care.!!!!!
- FURRYe38May 13, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Be sure to do a back up configuration to file for safe keeping on the RBR. Saves time if a reset is need.
Enjoy. :smileywink:
