paulw007
May 13, 2020Tutor
RBR50 Second hand purchased, how to register
Hi just purchased an Orbi RBR50 with satelite second hand. I have tried to register but it says the product already registed. I have sent an email but no reply as yet. I was hopping someone inthe com...
paulw007
May 13, 2020Tutor
All sorted, up and running and very good wifi. Thank you very much for your time and your help. Stay safe and take care.!!!!!
May 13, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Be sure to do a back up configuration to file for safe keeping on the RBR. Saves time if a reset is need.
Enjoy. :smileywink:
