KShivum
Oct 15, 2020Aspirant
RBR50 Seems like we are hitting max devices
Hi, so recently we ran into an issue where a lot of devices aren't able to get an internet connection but are connected to the internet, but when a device disconnects another one gets a connection. I ...
Mstrbig
Oct 15, 2020Master
KShivum wrote:
Hi, so recently we ran into an issue where a lot of devices aren't able to get an internet connection but are connected to the internet, but when a device disconnects another one gets a connection. I would understand if we had 200 devices but we have 27
Sounds like maybe you are out of available IP addresses.
Check your DHCP settings to make sure you allocated enough IP addresses.
Also check your subnet mask as it also determines how many IP addresses you are allowed to have.
KShivum
Also all of the computers are getting IP's but still aren't getting a connection, is that still correct?
