KShivum
Oct 15, 2020Aspirant
RBR50 Seems like we are hitting max devices
Hi, so recently we ran into an issue where a lot of devices aren't able to get an internet connection but are connected to the internet, but when a device disconnects another one gets a connection. I ...
Oct 17, 2020Guru - Experienced User
Try adding just 1 RBS now.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
KShivum
Oct 17, 2020Aspirant
One of them is less than 30 feet, but the other isn't, but we will probably change routers, We've had way too many issues with the Orbi routers and most of my family believes that mesh routers don't work at this point
- FURRYe38Oct 17, 2020Guru - Experienced User
Anything less that 30 feet is too close. Placement and distance is key.
I've had Orbi AC for a while now and work well with my 30 devices, wired and wireless. v16 FW. RBS50 and 1 RBS20.
Good Luck
- KShivumOct 17, 2020Aspirant
Would a satellite being too close cause these types of issues?
Yes. Distance and placement is key.
Also make sure FW is the same on the RBS series as well. They should be already.I found that v16 is the best and most stable version of FW IMO for the 50 series Orbi.
You might download v16 files for RBS and RBR. Use a wired PC and manually re-load the units using a web browser. Factory reset and setup from scratch. I'd run just 1 RBS intially, try to get the distance out to about 35 feet if your home is mostly wood and sheet rock.
What is the size if your home again? Sq ft?
