HuhWhoKnew
Aug 13, 2019Aspirant
RBR50 Set Up, Frequency Selection
Hi All, New to Orbi, just switched from Nighthawk X4S AC2600. I have ~ 1098 sf, 2 story. Router on 1st floor; satellite 1 - 1st floor ~ 30 ft away with kitchen cabinet wall between; satellite 2 - ...
- Aug 14, 2019
You might want to try lowering the power output of the RBR from 100% to say 50% as a test. Under Advanced Tab/Advanced Settings/Wireless Settings
It's up to the client devices to connect to the freqency they pick and choose to best suitable.
HuhWhoKnew
What wireless device are you using to speed test with? iPad 6th Gen using Ookla
What speed results do you get with a wired PC connected to the RBR? 200+ I was pretty much able to match wired speed when I had the AC2600 hooked up but I was only getting (paying) 55 mbps clocking 70+.
Any Wifi Neighbors near by? If so, how many? 8+, I live in a vertical condo so have 2 common walls.
Set 20/40Mhz Coexistence to 40Mhz only I only have Enable/Disable Option. When I Disable it does not provide a way to set to 20 or 40
Armor I cannot find where to disable
Aug 13, 2019Guru - Experienced User
HuhWhoKnew wrote:What wireless device are you using to speed test with? iPad 6th Gen using Ookla
Could be a reason for some wifi performances. Having many other wifi neighbors can be problematic. Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. You might want to try lowering the power output of the RBR from 100% to say 50% as a test. Under Advanced Tab/Advanced Settings/Wireless Settings
Set 20/40Mhz Coexistence to 40Mhz only I only have Enable/Disable Option. When I Disable it does not provide a way to set to 20 or 40. When you uncheck the 20/40Mhz box, this sets it to 40Mhz only.
Try under access controls? You may need to factory reset the RBR and setup from scratch and this time, don't enable Armor during the setup wizard process.
- HuhWhoKnewAug 14, 2019Aspirant
I enabled and disabled as you outlined. Found the Armor controlon the home page! Does not seem to have made that much difference.
Multiple networks close by is a likely suspect. I am going to ask my two common wall neighbors where their modem/routers are and try relocation. I may have to get a WiFi scanner and work through the channels too. I just got 146 mbps on a Lenevo ThinkPad, second floor directly above satellite 1 on first floor.
Also, what about designating what devices are on what satellite and what frequency they use?
I have 2 Firesticks. one next to satellite 2 and other next to satellite 1, and both are using the main router! Phones and iPads we dont stream with are using 5 ghz rather than 2.4.
- FURRYe38Aug 14, 2019Guru - Experienced User
