nroberts7984
Sep 27, 2024Aspirant
RBR50 settings change for faster internet?
Hey y'all, I just upgraded my internet service with my ISP from 1 Gbps to 2 Gbps. My issue is that when the tech checked the speed on his device it was pulling the full 2 gig service but my RBR50 is...
- Sep 27, 2024
So the speeds mentioned for 3Gb is a combined max total connection rate that is supported by the wifi in combination with 2.4Ghz and 5Ghz. Since the ethernet ports are limited by the max rate of 1Gb, WAN and LAN, you'll only see around 900Mpbs from these ports.
If you want to see 2Gb from the ISP, you'll need a different Orbi system that has higher connection rated WAN and LAN ethernet ports, i.e. Orbi 960 or 970 series or the Nighthawk RS series routers which are not MESH routers.
Sep 27, 2024Guru - Experienced User
nroberts7984
Gotcha, thank you. That's what I was afraid of
- FURRYe38Sep 27, 2024Guru - Experienced User
š
