aidenmcdaniel
Nov 25, 2020Aspirant
RBR50 setup with network switch
I am going to be setting up my RBR50 with a network switch. The reason for this is because I'm on a community network with no access to the main network modem. Currently I'm setup using a linksys wifi...
- Nov 25, 2020
Yes, like I said, if you need a switch then install one at the walll out let then connect the RBR to the switch. But nothing else can connect to the switch. If you need more ports in back of the RBR, then you can add a switch here as well.
Good Luck.
Nov 25, 2020Guru - Experienced User
Something to ask the Mfr of this switch or your network administrator/ISP if your network. IF there already is a private network, you could configure the Orbi system for AP mode.
Good Luck.
