aidenmcdaniel
Nov 25, 2020Aspirant
RBR50 setup with network switch
I am going to be setting up my RBR50 with a network switch. The reason for this is because I'm on a community network with no access to the main network modem. Currently I'm setup using a linksys wifi...
- Nov 25, 2020
Yes, like I said, if you need a switch then install one at the walll out let then connect the RBR to the switch. But nothing else can connect to the switch. If you need more ports in back of the RBR, then you can add a switch here as well.
Good Luck.
Nov 25, 2020Guru - Experienced User
Something to ask the Mfr of this switch or your network administrator/ISP if your network. IF there already is a private network, you could configure the Orbi system for AP mode.
Good Luck.
aidenmcdaniel
I dont quite understand? The main community comcast modem sits in a basement electrical closet in the main common house. According to the orbi setup instructions, I would plug the orbi into the modem and reboot the modem. Not possible for me to do this. Instead that modem is constantly on and running the network for the whole community. I'm simply plugged into a network jack in my house - which is on a patch panel. Because there is only one main line, I can't patch my office network jack into the main line, and the orbi. Instead, I will be plugging the switch into the main port, and running a patch from the switch to the network jack in the office, and then from the switch to the orbi. I'm just wondering if this setup will be similar to what I had with the linksys wifi router?
