David79NL
Dec 23, 2020Aspirant
RBR50 shutting down LAN wired ports
Hi, My setup has been working for months like this and only last weekend i have started to see problems. My internet is connected to the router of the provider who passes it through to the RBR...
- Dec 24, 2020
The Powerline adapters arrived and are currently working - fingers crossed it stays that way. I can always play around with the Moca's later to see if they are somehow faulty.
David79NL
I found this a couple of times in the soap agent log:
{2020-12-22 16:28:43}[agent.c:1108] kill last soapclient pid 1018 is 0
{2020-12-22 16:28:43}[agent.c:403] satellite 38:94:ED:BE:XX:XX disconnect
{2020-12-22 16:37:24}[agent.c:1130] config check start, config is satellite, delimiters is
{2020-12-22 16:37:24}[agent.c:1134] config satellite1 is 28:80:88:FC:XX:XX 192.168.1.19 RBS50 5LT29XXXXXXXX -74 V2.5.2.4 1 28:80:88:FB:50:A9 5GHz 2
{2020-12-22 16:37:24}[agent.c:1134] config satellite2 is 38:94:ED:BE:XX:XX 192.168.1.13 RBS50 5PV198XXXXXX -100 V2.5.2.4 1 28:80:88:FB:50:A9 5GHz 0
{2020-12-22 16:37:24}[agent.c:1134] config satellite3 is
{2020-12-22 16:44:52}[agent.c:472] SOAP AGENT: update acl config, run AccessControl to sync to all satellite
{2020-12-22 16:44:52}[agent.c:517] satellite 38:94:ED:BE:XX:XX reconnect
Google doesnt give me anything and the log also does not tell me about the disconnected wired ports. Satelite 2 is the one connected via Moca.
