David79NL
Dec 23, 2020Aspirant
RBR50 shutting down LAN wired ports
Hi, My setup has been working for months like this and only last weekend i have started to see problems. My internet is connected to the router of the provider who passes it through to the RBR...
- Dec 24, 2020
The Powerline adapters arrived and are currently working - fingers crossed it stays that way. I can always play around with the Moca's later to see if they are somehow faulty.
Dec 23, 2020Guru - Experienced User
What mode is your ISP modem working in? Router or Modem?
I would remove these moca adapters and try the RBS wirelessly connected to see if the RBS works ok.
- FURRYe38Dec 23, 2020Guru - Experienced User
Also you might revert back to v16, Ive found that v4 and follow on version of FW cause problems with ethernet connected RBS.
- David79NLDec 23, 2020AspirantThe ISP device is working as a modem.
Without the Moca’s it works but the connection to the RBS is very bad.- FURRYe38Dec 23, 2020Guru - Experienced User
Sounds like the Moca adapters are the problem...Any chance of running a Cat6 lan cable instead out the remote RBS?
- David79NLDec 23, 2020AspirantI wish - i am sure i could rip out the coax and replace it with a cat6 but thats exactly what i wanted to avoid ;). Will try a pair of avm powerline adapters today.
