David79NL
Dec 23, 2020Aspirant
RBR50 shutting down LAN wired ports
Hi, My setup has been working for months like this and only last weekend i have started to see problems. My internet is connected to the router of the provider who passes it through to the RBR...
- Dec 24, 2020
The Powerline adapters arrived and are currently working - fingers crossed it stays that way. I can always play around with the Moca's later to see if they are somehow faulty.
Dec 23, 2020Guru - Experienced User
What mode is your ISP modem working in? Router or Modem?
I would remove these moca adapters and try the RBS wirelessly connected to see if the RBS works ok.
Also you might revert back to v16, Ive found that v4 and follow on version of FW cause problems with ethernet connected RBS.
