David79NL
Dec 23, 2020Aspirant
RBR50 shutting down LAN wired ports
Hi, My setup has been working for months like this and only last weekend i have started to see problems. My internet is connected to the router of the provider who passes it through to the RBR...
- Dec 24, 2020
The Powerline adapters arrived and are currently working - fingers crossed it stays that way. I can always play around with the Moca's later to see if they are somehow faulty.
David79NL
The ISP device is working as a modem.
Without the Moca’s it works but the connection to the RBS is very bad.
Dec 23, 2020Guru - Experienced User
Sounds like the Moca adapters are the problem...Any chance of running a Cat6 lan cable instead out the remote RBS?
- David79NLDec 23, 2020AspirantI wish - i am sure i could rip out the coax and replace it with a cat6 but thats exactly what i wanted to avoid ;). Will try a pair of avm powerline adapters today.
- FURRYe38Dec 24, 2020Guru - Experienced User
You cn test the RBS via ethernet as a quick test with a LAN cable in the sane room to make sure that still works.
Hopefully a PL configuration will fix this for you.
- David79NLDec 24, 2020Aspirant
