Glenvis
Dec 25, 2019Star
RBR50 signal strength for Samsung QLED is low
My Orbi RBR50 is working just fine, laptop, Blink, & Lutron all working well. My remote is in my rec room about 13 feet from my Samsung QLED TV - straight across the room, nothing in the way - all un...
CrimpOn
Dec 25, 2019Guru - Experienced User
When I briing up the Device Manager, it shows a list of connected devices. I tap on one, and it brings up a full page display with all sorts of details. The bottom item on my display is "Link Rate".
Glenvis
Dec 25, 2019Star
Not sure where you are finding this info. In Windows 10, Device Manager, the Orbi doesn't show up.
In the Samsung TV, looking at Settings, Network, Network Status it only shows "Your TV is connected to the internet."
