ElCapo
Oct 15, 2018Luminary
RBR50 Sky Q Intermittent Connection
Hello All
I have recently had Sky Q installed with the 2 TB box and 1 Sky Mini Box.
My set up with Orbi is as follows:
Vodafone Broadband and Router
1 x RBR50 in Access Point Mode
2 x RBS50...
- Nov 06, 2018
Hello
Just throught I would post an update to this in case anyone ese finds the problem.
I eventually purchased a Netgear DM200 EUS modem and athough I had a few issues sorting it out I eventually got it into Bridge Modem and connected to my Vodafone broadband.
Following that I set up the Netgear Orbi in Router mode which all worked well.
Since then, I have not seen the regular drop out of connection on my Sky Q service so fingers crossed this has sorted the problem :-)
Will advise if anything changes.
ekhalil
Oct 15, 2018Master
What other wired devices do you have connected to the switches or to the Orbi Router/Satellites?
