jboogie15
Feb 17, 2020Aspirant
RBR50 slow connection upstairs
Hey, Wifi works perfectly downstairs and I'm getting the advertised 200mbps all throughout my first floor. However, upstairs the connection is slow and intermittent despite having two satellites ...
tomschmidt
Feb 17, 2020Virtuoso
jboogie15, if you are running v2.5.0.x firmware, and it was retracted by Netgear after many bugs and stability issues were found. NG disabled autoupdate in recent releases due to the issues that it has caused. I suggest manually upgrading your RBR50 and satellites to v2.5.1.8 if you are running v2.5.0.x firmware. It is available from https://www.netgear.com/suppzio fort/product/RBR50.aspx#download
jboogie15
tomschmidt I'm currently running firmware V2.3.5.30 on my router should I go ahead and manually update to V2.5.1.8.
- FURRYe38Feb 17, 2020Guru - Experienced User
v2.5.1.8 is good to upgrade. Solid and stable. Upgrade the RBS first if you have them, the the RBR lasty.
jboogie15 wrote:tomschmidt I'm currently running firmware V2.3.5.30 on my router should I go ahead and manually update to V2.5.1.8.
