jrheuman
Jan 15, 2020Follower
RBR50 Slow Hard Wired Download Speeds
When I test the speed through the Orbi App or logged in via orbilogin.com the download speeds are 460 to 470 mBs. On my mac hardwired through a Netgear 1GB switch and Cat 5e wire my download speeds ...
euidhawiojp12
Jan 17, 2020Aspirant
Tried with Surface Book and MacBook Pro as well as phones that are gigabit internet capable. All devices are on 5ghz according to Orbi "connected devices list". Doesn't matter which device connected on wifi, all show download speed cut in half. However, if I plug any laptop directly into Orbi, download speed is at full 300mbps+. Something not right with wifi signal.
- FURRYe38Jan 17, 2020Guru - Experienced User
Need more information then this.
What is the Mfr and model# of the ISP modem the NG router is connected too?What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
euidhawiojp12 wrote:Tried with Surface Book and MacBook Pro as well as phones that are gigabit internet capable. All devices are on 5ghz according to Orbi "connected devices list". Doesn't matter which device connected on wifi, all show download speed cut in half. However, if I plug any laptop directly into Orbi, download speed is at full 300mbps+. Something not right with wifi signal.
- euidhawiojp12Jan 18, 2020Aspirant
Tried with Surface Book and MacBook Pro as well as phones that are gigabit internet capable. All devices are on 5ghz according to Orbi "connected devices list". Doesn't matter which device connected on wifi, all show download speed cut in half. However, if I plug any laptop directly into Orbi, download speed is at full 300mbps+. Something not right kodi lucky patcher nox with wifi signal.
