jrheuman
Jan 15, 2020Follower
RBR50 Slow Hard Wired Download Speeds
When I test the speed through the Orbi App or logged in via orbilogin.com the download speeds are 460 to 470 mBs. On my mac hardwired through a Netgear 1GB switch and Cat 5e wire my download speeds ...
euidhawiojp12
Jan 17, 2020Aspirant
Tried with Surface Book and MacBook Pro as well as phones that are gigabit internet capable. All devices are on 5ghz according to Orbi "connected devices list". Doesn't matter which device connected on wifi, all show download speed cut in half. However, if I plug any laptop directly into Orbi, download speed is at full 300mbps+. Something not right with wifi signal.
Jan 17, 2020Guru - Experienced User
Need more information then this.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
euidhawiojp12 wrote:Tried with Surface Book and MacBook Pro as well as phones that are gigabit internet capable. All devices are on 5ghz according to Orbi "connected devices list". Doesn't matter which device connected on wifi, all show download speed cut in half. However, if I plug any laptop directly into Orbi, download speed is at full 300mbps+. Something not right with wifi signal.
