Coalhole
Nov 30, 2023Guide
RBR50 Slow Internet speed
I have an RBR50 in router mode connected to Virgin media hub working in modem mode, i.e. no wireless. My VM package was, until recently, 125mb. Speed tests showed download of around 92mb, upload arou...
- Nov 30, 2023
Coalhole wrote:
Speed tests showed download of around 92mb, upload around 19mb.
A speed "just under 100mb" is highly suspect. Modern systems have electronics built into the physical Ethernet hardware to auto-negotiate the highest speed that the devices on each end of the cable will support.
https://en.wikipedia.org/wiki/Autonegotiation
It would be very useful to know what speed has been negotiated between the Virgin hub and the Orbi router.
Log into the Orbi web interface and open the Advanced Tab Home Page.
Click the blue box, Show Statistics.
If this shows "100M/Full" then something is usually wrong with the cable pathway between ISP device and Orbi router.
p.s. The router also has a method to report internet speed that can be accessed from the web interface or from the Orbi 'app'.
Coalhole
Nov 30, 2023Guide
Thanks CrimpOn. It does indeed show 100M/Full for the WAN port. I'll change the cable and see what I get.
CrimpOn
Nov 30, 2023Guru - Experienced User
Please post the results of changing the cable. All sorts of things can happen to:
- The actual cable itself
- The RJ45 plugs which are crimped onto each end of the cable
- The RJ45 jacks on the devices. If even one of those tiny gold wires is bent or doesn't make contact then the maximum connection rate falls to 100M/Full.
- CoalholeDec 01, 2023Guide
Brilliant. Thanks CrimpOn it was a cable problem. Now getting downloads up around 270mb.
- FURRYe38Dec 01, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
