r3id's avatar
r3id
RBR50 Slow Speeds and Intermittent Connection
My internet connection has been very slow and cutting out over the last several days.  The download speeds are roughly a third of what I get when directly plugged into the modem.  I updated to the la...
  • FURRYe38's avatar
    30 feet is recommended in between them to begin with depending upon building materials. Move the satellite farther away.
    Then try setting manual channel 1, 6 or 11 on 2.4Ghz
    Also as a test, turn OFF The satellite and run the router only. Do you still see the problem?
