AlexB56
Dec 05, 2022Aspirant
RBR50 slow speeds
hi there I have just upgraded to a 1GBps fibre broadband. When I connect directly to my broadband provdier's router wifi I can get about 580MBps download. But when I connect via the Orbi RBR50 (which...
- Jan 30, 2023Sounds like you are using a cat 5 Ethernet cable to connect your Orbi, switch to a cat 5e or 6. Test wired speeds from Orbi and then wireless.
Dec 05, 2022Guru - Experienced User
2 things.
If the isp supplied device has wifi, it causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
Its also worth noting that sometimes changing speeds is helped by a factory reset and reinstall. Have you tried that.
