AlexB56
Dec 05, 2022Aspirant
RBR50 slow speeds
hi there I have just upgraded to a 1GBps fibre broadband. When I connect directly to my broadband provdier's router wifi I can get about 580MBps download. But when I connect via the Orbi RBR50 (which...
- Jan 30, 2023Sounds like you are using a cat 5 Ethernet cable to connect your Orbi, switch to a cat 5e or 6. Test wired speeds from Orbi and then wireless.
037
Jan 30, 2023Initiate
- CrimpOnJan 30, 2023Guru - Experienced User
037 wrote:
Sounds like you are using a cat 5 Ethernet cable to connect your Orbi, switch to a cat 5e or 6. Test wired speeds from Orbi and then wireless.Electronics built into Ethernet adapters perform auto-negotiation when they detect that they are connected to another device:
https://en.wikipedia.org/wiki/Autonegotiation There is nothing the user can do to affect this function. A speed just slightly less than 100Mbps is characteristic of a 100M/Full connection. (There is some overhead in Ethernet. Not nearly as much as in WiFi, but there is still some.) This could be caused by any number of things, including the actual cable and the plugs that have been crimped on each end.
One tipoff is to open the router web interface (http://orbilogin.net ) and navigate to the Advanced Tab. Click the blue box "Show Statistics" in the top right box. Here's what my RBR50 looks like:
If your WAN port reports 100M/Full, then it's time to change the cable for sure.
- captm0rgan77Feb 12, 2023Aspirant
I am having the same issue and did what you suggested and my STATISTICS look exactly like yours but when I run speed tests from several different sites I get speeds around 36mbps. When I connect directly into my modem I get the full 800mbps I am paying for. So that tells me it's not the PC's hardware or LAN cable.
- AlexB56Feb 13, 2023Aspirant
I read previous posts of support that suggested it was the cable between the router and the wifi. I had a cat 5e cable and upgraded it to cat 6 - the problem has been resolved so you might wish to check that.
Thanks for this. I was using a cat 5e and the speeds were poor (ie less than 100. But upgraded to cat 6 and the speeds are now comparable to the hyperoptic router.
Many thanks
- FURRYe38Feb 13, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
