AlexB56
Dec 05, 2022Aspirant
RBR50 slow speeds
hi there I have just upgraded to a 1GBps fibre broadband. When I connect directly to my broadband provdier's router wifi I can get about 580MBps download. But when I connect via the Orbi RBR50 (which...
- Jan 30, 2023Sounds like you are using a cat 5 Ethernet cable to connect your Orbi, switch to a cat 5e or 6. Test wired speeds from Orbi and then wireless.
037
Jan 30, 2023Initiate
AlexB56
Feb 13, 2023Aspirant
Thanks for this. I was using a cat 5e and the speeds were poor (ie less than 100. But upgraded to cat 6 and the speeds are now comparable to the hyperoptic router.
Many thanks
- FURRYe38Feb 13, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
