Squiner
Oct 06, 2020Aspirant
RBR50 slow upload
I have my RBR50 connected directly to my Fios ONT. I don’t have cable tv. I have 100/100 service. Speed tests on a wired laptop to Orbi I get 100/25. When the laptop is connected to directly to the ON...
Oct 06, 2020Guru - Experienced User
Has a power off on the ONT and RBR for 1 minute then back on been performed since last update?
- SquinerOct 06, 2020AspirantThanks for the quick reply.
The Orbi firmware is v2.7.0.70.
The ONT MFR is 04/2019 and it’s model # I-211M-L
Power of has not been conducted on the ONT. Orbi has been rebooted a few times. I can try that after my wife finishes work.
I did a setup wizard on the Orbi which appeared to be a set up from scratch. Is that accurate?
