joeschmo90's avatar
joeschmo90
RBR50 slow wifi connection speed
I've got a CM1000 modem connected to my RBR50 Orbi and I am having very slow wifi connection speeds. I'm getting about 1/3 of my actual download speeds and my laptop devices do not seem to want to connect to 5Ghz band. I'm not sure what to do to right this issue I'm having.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello joeschmo90
    Have you tried to adjust the wireless channels of the 2.4ghz and 5ghz networks?
    DarrenM
    • joeschmo90's avatar
      joeschmo90
      Thank you for your response Darren.
      Ive changed the wifi channels multiple times after scanning to see which was least populated.  I have also done a factory reset as well.
      After browsing around a little could this be attributed to the firmware update?
      • DarrenM's avatar
        DarrenM
        Have you tried to enable beamforming and mumimo?
        DarrenM
