badler4
Jan 29, 2021Aspirant
RBR50 slow wired speeds
I check the speed test on the Orbi app, and I'm getting 600-750Mbps (paying for 912Mbps from Spectrum). I have a wired connection, Cat 8, from my ethernet port on the Orbi router to my laptop dockin...
Jan 29, 2021Guru - Experienced User
Can you connect your laptop directly to the RBR and by pass the dock station?
Do you have a different wired PC to test with and compare results?
Use Ooklas installable speed test app for Windows...
badler4
firmware is V2.5.2.4 on the Orbi
